Custom GSX
- 84
- 0
- May 13, 2012
Denver,
Colorado
So I have a 90 GSX and recently my power steering hose started leaking and oil got to the alternator. It's started smoking and then glowing with some sparks. I checked it with a volt meter and 19.6volts Awww!!! So I pulled it and replaced it with a reman alternator. Checked again and still 19.6 volts and 20 volts at the battery. So my question is this normal which I don't think so and is there a voltage regulator somewhere else in the engine by to replace??????? Thanks tuners!
