93 gsx skidz
- 43
- 0
- Sep 15, 2012
masontown,
Pennsylvania
i have a 93 eclipse gsx which had a 1 1/2 gen 7 bolt so i rebuilt a 1990 6 bolt and installed it in my car then i put a new 16g turbo on which was already on the car and it started fine no problems ran great just drove around the block scared to break something then pulling into my driveway and the car stald then it wouldnt crank i would just hear a loud ticking noise then waited and the car finally cranked now it cranks every time but it wont stay running not even long enough to give it gas it sounds like bad plugs and wires or a bad injector. i was told by an expert on these cars that it was an ecu but i dont have the money to buy another one so i have to make sure its bad i checked for spark and its good i check for fuel all the way up to the fuel rail and its good however i didnt check the injectors ### i dont know how. i think it could be the knock sensor or the cam sensor but the guy that said its the ecu is a lot better at this than me so i just need more people to confirm it let me know what you think
