2G Custom Gauge Cluster (Tutorial)
PXHero
166
9
Aug 19, 2008
Columbus, Ohio
Quite some time back, I started a rebuild project on my 99 GSX. It's moving along sloooooooooooooooooowly. However, I finally have enough done on my gauge cluster to write up a bit of a tutorial.
First things first, remove and disassemble your cluster. If this is difficult or heart breaking for you to do, you won't like what's coming up, turn back now. ;)
Break it down to the parts shown above. Since I don't know the proper names for these items, I'll just call them (in order) glass, box, and trim. The box is (at least for the sake of this tutorial) facing you, with the bottom facing the bottom of the image.
I trashed all the extra pieces of my old cluster since I wouldn't be using them in my new one. I did make a note of my milage, just on the off chance I can input it into my new speedometer's odometer. :thumb:
Next I ripped out the excess plastic trim around the old gauges and lights. Be careful to leave a bit of plastic trim around the edges of the old cluster. It's much cheaper to buy sand paper and get it closer to the vertical walls of the trim than it is to buy another cluster.
After I got the majority of the trim out, I went back with a drum sander and got the rest so it was flush with the walls. I also got a bit of the wall with the sander, but that's ok for my application because I will be using a texture coating on all the surfaces for an "OEM" look. :thumb:
For the next step, I begged my boss to use the shop's scroll saw. If your boss is as forgiving as mine, he won't mind if you break a few blades. (I broke 3...:ohdamn: Not bad for my first time using a scroll saw though... Anyway, back to the tutorial)
Cut out as much of the plastic back as you can while still retaining the supports (detailed in the second photo above). These will be holding your new gauge plate in place by pressure so you won't need glue or screws. Now that the back of the box is open, you'll notice that it's VERY flexible. Take care not to flex it too far, it will break.
Because I opted to flush my gauges into the cluster, I used 3/4" MDF (Medium Density Fiberboard) for my new gauge plate. After that last step, I got sidetracked and forgot to take pictures of shaping the MDF to fit the cluster, but maybe I can get enough words out here to give you the idea.
I cut down a piece of MDF a little larger than the trim piece. Then I did a lot of sanding on the belt sander to get it the approximate shape of the trim. Since the 2G cluster has a slight angle at the bottom of the box, I needed to bevel the bottom edge toward the back of the plate. This took a little guess work, a lot of luck, and a lot of test fitting. And honestly, a second piece of MDF and a "do over." Once the second piece of MDF was close enough for who it's for (me) I proceeded to further modify the box.
The "finished" plate, complete with trim tracing.
I did this using a very rough sanding disk chucked into my drill and a little downward pressure. Since the plate I used was 3/4" thick, I measured flush from the front side of the box down 3/4" on each support. I made a nice 3/4" template for this using scrap from my gauge plates. I drilled a hole into the scrap that was about the same diameter as the support posts, and then cut the piece roughly in half, bisecting the hole. Then I placed the box face side down onto a table, placed the template's groove onto each support, and made a mark. Easy as that! Then a little grinding, a little test fitting, a little grinding, a little test fitting, etc. Until the plate fit flush with the front face of the box.
Next I plotted out where I wanted the gauges. This took a lot of time, and measuring, marking, erasing, remeasuring, remarking, etc. Finally, I ended up with this!
If I wanted to go through the headache of reforming another gauge plate, I would only do 4 gauges in the cluster. It's much more forgiving because it allows for more space between the gauges, and being 1/32" off in your measurements doesn't show as clearly in the final product.
After I got everything plotted, now it was time to beg the boss to use the drill press. :pray: After permission was granted, I chose a hole saw that was as close to the diameter of the smaller gauges as possible. (Your forgiveness is required here as well, since I once again got sidetracked and didn't take pictures of the process. Those pesky customers, always wanting to buy stuff... :toobad:) I recommend using a tiny drill bit to get a pilot hole started for the center of each gauge location, and then stepping it up to something about 1/2 the size of whatever bit is in your hole saw. I clamped the gauge plate to the press, and began cutting holes. Once the small gauge holes were cut, I repeated the process on the larger holes, using the appropriate size hole saw of course. I highly recommend the use of a drill press for this portion, because if you don't get the holes exactly parallel to the plate, then your gauges won't sit right in the cluster. Also, don't be surprised if you can't find a hole saw the exact size of your gauges. My larger gauges slipped easily into place, but I had to sand out the holes for the smaller gauges a bit in order to get them to fit right.
After all the holes were cut, it was time to create the counter sink to flush the gauges. Using a router, a flush bit, and a good assortment of bearings, I carefully routed the counter sink for each gauge. The key here is to find a large enough flush cutting bit, and a bearing that will make up for the leftover space between the chassis of the gauge and the overall diameter of the gauge. (This process would have been much easier had I not purchased surface mountable gauges. If you have straight body gauges, ex. 52mm face with a 52mm chassis, you won't need the router, but you will have to glue the gauges in place in the later stages of the build) Using more of the scrap from the gauge plates, I made test cuts, and fine tuned the depth of the router cut. Then, routed until my heart was content!
Test fitted gauges.
Close up of the counter sink.
Next it was time for a test fit to make sure everything still closed perfectly.
Oooooooo, pretty...
Now that I knew things were coming along, it was time to prepare the surfaces for texture. I cleaned the plastic using some adhesive remover. Then I used 120 grit sand paper and roughed up all the surfaces that would be getting paint. Once I was satisfied that the surfaces were even and clean, I used SEM brand chip guard in Satin Black to cover the trim and the gauge plate. You'll probably need to go to a paint specialty store in order to get this, or search the vastness of the internet. Or use whatever texture you like, SEM doesn't pay me to promote their stuff. I sprayed each piece separately and from a distance of about 2 1/2 feet. Spraying the parts separately aides in an even coat, and spraying the texture coating from a distance ensures that the texture doesn't become a big blob on the cluster.
Images of the results of using texture.
After letting the texture coating cure for a couple days, I fitted the gauges into the plate and assembled the cluster.
It was then that I noticed the slight scratches on my glass. Well, this won't do. I'm spending all this time, effort, and money to have nice things, and my glass is scratched. So, I scratched it further using 1200 grit, 1500 grit, and 2000 grit sandpapers and a little wet sanding magic. I did this in preparation for polishing. Something very similar to fixing the haze on our wonderful 2G headlights.
Start with the 1200 grit sand paper, and soak it really well in water. Ensure that when you transfer it from your water source that you take some of the water to your glass. Sand in a circular motion and continue to wet the surface until it feels uniform under your finger tips. At this point, flip the glass over, and repeat. Make sure you get into the “corners” on the back of the glass. Now switch to the 1500 grit, and repeat the process. And then step down to the 2000 grit, and repeat the process yet again. You should end up with glass that looks like this.
Once you’ve gotten through the 2000 grit sand paper, rinse the glass thoroughly. I used a paper towel to dry it (Why not? It’s already scratched up! :thumb:)
Use whatever method you prefer to polish the glass. I prefer to use a 4 step process of liquid compounds and pneumatic DA sander with the appropriate polishing pads.
I haven’t gotten around to taking pictures of the polished glass yet (honestly I’m a little afraid to touch it), but I’ll get them on here tomorrow with the (almost) completed cluster. (I still need to get turn signal LED’s)
They're Speedhut brand gauges, and completely customizable. If I find the time, I'll get pics of the illumination on here too. Blue hash marks with red needle.
All of my fuel gauges are going where the radio is normally located (I've got photos for that too, and another write up that needs doing...) I'll be remote mounting my radio in or near the glove box, and using an RF remote to operate it.
Here's a "teaser" :sneaky:
What gauges and how do I get them?
Speedhut is the name of the gauge company.
Installed might be a bit since my dash is on the bench behind my stripped GSX. I'm going to try to find the time to get some illuminated pics taken. I haven't even seen them lit up yet, so hopefully Speedhut sent me the right colors...
Very very nice!! I always thought about doing something like that but I would rather invest in a tablet and have my megasquirt displayed on that. Any ways good job and what is that texture stuff? Or did you tell us and I just can't read?
Found my answer... Just never heard of it
Are you going to have to wire the gauges in order to work or is it plug and play? Dash gauges that is. Speedhut also makes a whole gauge mat like thing that is fully customizable and is very easy to install.
Custom Gauges by SpeedHut
They are all electronic gauges, but unfortunately they do require their own senders and wiring. Plug and play is easy, but I like doing things the fun way! :hellyeah:
Also, I looked through Speedhut's gauge products, and couldn't find what you were referring to. All I saw were the stock chrome and stainless overlays... Do you know the product ID number?
And as promised, illumination photos! All of the cluster photos have the polished glass installed, note how clear it is now!
so awesome!! nice work and selection of gauges. :applause:
The “Fuel Cluster” was primarily the same as the main cluster, with a few exceptions.
First I needed to create a plate the same size as the double DIN opening. Again, I used 3/4” MDF. Simple Bob Vila work here, measure twice, cut once. I still cut mine a little larger and sanded a bit on the belt sander to get things nice and tight. Mine was tight enough that if I pressed the plate into the opening, it would stay by pressure alone, and I even damaged 2 of my corners removing it. :shhh: Don't forget to plot and measure your gauge locations!:thumb:
Next you want to head over to your drill press (beg the boss:pray:, etc.) and drill out the appropriate holes. Route the edges if needed to flush the gauges.
Next I needed to create a bracket system to temporarily hold the plate in place (sorry again, I don’t have pictures of this, but I did draw reference marks on the back of the plate that you’ll see in the third image). The important thing here is to support the plate in the radio trim so it will stay level while your adhesive is curing.
Once you’re satisfied with your plate supports, remove them and remove the plate. Your next step is to bevel the front edges of the plate just a little bit. I sanded about 1/16” into the face of the plate. You don’t need much. The purpose of this is to allow the adhesive somewhere to “grab” onto the plate. I used a two part 5 minute epoxy that comes in side by side tubes and uses a device similar to a caulking gun to squeeze the two parts out equally.
Next rough up the edges of the double DIN opening with 80 grit sand paper. This is also to give the adhesive something to “grab.” Then re-affix your plate to the trim using your brackets. If you made your plate as tight as I made mine, you’ll notice that with the edges ground down, the plate doesn’t quite fit perfectly anymore. I had to readjust my brackets a bit to keep the plate level in the double DIN opening.
I then spread a thin bead of the 5 minute epoxy into the crack all the way around the plate. Don’t be like me, wear gloves. I wasted a little of my setup time digging in my tool cart to find a plastic bag to smooth the epoxy with, and still ended up with quite a bit on my hand.:ohdamn:
Quickly flip the cluster over, and run another bead of epoxy all the way around the plate. This ensures that the plate is held in place on both sides of the trim.
Note the stenciling I drew around my brackets.
After the epoxy has cured (I left mine over the weekend and without the brackets attached, one of my corners dropped about 1/16”:cry:) you’ll want to level the surface with some sanding, a little body filler (AKA Bondo), and a LOT more sanding. Once you’re satisfied with the curves of your corners, it’s time for texture paint!
Again, prep your surfaces with some 120 grit sand paper. It took me a couple coats and even a “Do Over” to get the desired texture effect. The great thing about the texture coating is you can sand it down if it gets too thick, and start over without any more prep.
And there you have it.
The only thing i found "customizable" on that site is this:
Eagle Gauge Glow Dials and Custom Gauges by SpeedHut
and:
Mitsubishi Gauge Glow Dials and Custom Gauges by SpeedHut
Maybe he can clarify?....
In any case love the project looks good.
I gotta say I am utterly impressed with your fit and finish overall. I'm so glad you went with a textured look instead of a gloss sheen. I LOVE the OEM style textures to really make these type of modifications blend in.
Did the texture paint create a slightly soft texture, sort of like rubberized splatter, or a hard texture closer to plastic?
