deank1
- 36
- 1
- Mar 23, 2009
Cincinnati,
Ohio
Before anyone says it, yes I have searched and I have done my research on this subject. My problem however I cannot figure out.
I installed a rebuilt 95 420a into my 98 eclipse. It is 100% hooked up with a new crank angle sensor, Cam position sensor, and many other new sensors. I am having trouble getting power to the coil pack. When I turn the key to the on position, I am getting the CEL and the other lights and when crank I have no movement on the tach.
Last night i was doing a little digging in the car and took the battery out. I checked for obvious things like the EGR burning the wires and such. I hooked the battery back up and had power to the coil for appx 5 minutes. Then it was dead again. I only get power to the coil in the first 5 or so minutes that the battery is in the car, then it looses it.
Can anyone help?
Can anyone help?
