triston2469
- 231
- 0
- Sep 15, 2012
Yukon,
Oklahoma
So im having a few throttle issues. When I start the car it fights to stay running and pretty much dies right off the bat so to keep it running you have to play with the throttle. Then after it has ran a while and you drive for a little it idles anywhere from 2000-3000 rpm. The other issues I'm having is that when it gets up to 3500 RPM while driving it studders really bad. The car sat for about a year before I bought it and for this to be the only issue I'm having I think its pretty good.
Here is what I have tried so far thinking it would fix the idle issue and studder issue:
Cleaned the air filter cause it was horrible. Luckily it has a K&N.
Checked spark plugs and they looked like they were fouled up with carbon really bad so i changed them.
I have adjusted the throttle cable so that it is not just dangling and not too tight.
I am kinda confused on what the problem is. I'm thinking that the issue could possible be the Throttle Position Sensor, but im not exactly sure.
