ShaneShane2510
- 61
- 0
- Jul 7, 2012
Brooklyn,
Wisconsin
Hello everybody. i have a 1g 91 gsx with a bui;t motor and a 16g running 15psi. recently i was sort of beating on it, and now at idle, the check engine light comes on, but the second you with the gas or raise the idle, it goes away. i thought it could be my oil pressure, but my oil is at the correct level, and there is no noticable leaks anywere, includinng around my oil cooler. if anybody has any insight on how i could fix this problem that would be great! Thanks!
