Aphix
- 320
- 1
- Aug 14, 2008
Salina,
Kansas
I just recently did a head swap due to a snapped timing belt. After I swapped out the head and got it fired up, I began to have an oil leak that seems to be originating somewhere on the timing belt side of the engine near the bottom. It's a fairly severe leak leaving a decent oil spot each time I park.
I can't figure out what it could be coming from though that has changed? I dont think its the cam seals as I had the head hot tanked and there are no signs of oil runs. It was resurfaced as well so I can't imagine its coming from the HG. The turbo oil feed/drain looks to be solid. I can't think of what else might be causing this?
