dsmdeliveryboy
- 2,054
- 5
- Aug 14, 2007
Medford,
Oregon
Ok so my car lost ALL power and was just making a clicking noise and my battery terminal was getting hot and so I started going through and checking what could be bad. So after I spend a lot of time going through stuff I find out my ignition switch is the problem so I snip all the wires and start going through each wire with a tester and I test the black wire with the white stripe and try adding power from the tester(says on here ignition, fuel)it clicks and loses all power and even blows the fuse in my tester, and as soon as it is removed it clicks again like its clicking something off like its a timer or something. I have no idea what it could be, if anyone knows please help.
