GSTurbo1
- 610
- 1
- May 2, 2012
Pickens, SC,
South_Carolina
Yep, so i'm pretty sure I bought my car with a blown head gasket and I finally demolished it. The car was running hot around town, so I decided to run it for a little bit w/out the t-stat. It ran super cool for a little while, until I parked it and realized it drank about a gallon of water in no time. And plus it was making it sound like a subaru at low rpm's, making me think its fouling one or two plugs out from all of the coolant leaking into the cylinder. So I start breaking it down, remove VC, exhaust mani, turbo and down pipe. And find oil on top of plugs 1 and 2.
Anyways i'm 100 percent sure bad headgasket, could this lead to my low compression results?
I feel pretty confident I can do this replace, just going to take my time and save myself about 800 bucks. However, my crankshaft pulley is not original and does not have the timing mark for TDC. Is there another way maybe by marking the camshafts to find TDC?
