samus21
- 150
- 0
- Jan 27, 2012
Shrewsbury,
Pennsylvania
I have 420a ecu and i found a f/ic but I wanted to know if there is a standalone so I can replace it all together to make it more simple and easy to use.
You have no mods listed for your car why do you need a standalone ECU?
First mod for me was ECMlink, tuned the car stock and made considerable amount of power more then when I first got it. We all know how far we can push stock components
None of it really does except standalones, maybe SAFCIs everything else talked about work on 420a's?
So how would I go about tuning my ecu? just dyno and flash the ecu?
what about mega squirt?
Tuning adds power. Going from batch injection and ignition to full sequential versions of those adds power.
I just bought crower cams and I have a magna flow exhaust and I about to get cam gears and a new belt. I wanted to get it tuned but I wasn't sure If you could get the stock ecu tuned? I wanted to take full advantage of the cams im getting.
Are you trolling, or has someone educated you improperly?
If you put the stock ECU back you'll have to put the stock injectors and map sensor back in, along with any other sensors you changed to run the stand alone ECU. It's a pain that most people aren't willing to go through.
The plug in test needs an OBDII computer to talk to and make sure all the sensors are working properly.
