rinmancustom
- 82
- 0
- Feb 15, 2009
wixom,
Michigan
Okay I need advice. I own a 96 eclipse gsx. I kept getting p0340 codes. Which is cam shaft position sensor. Mine is bad so what I did is put in a 1g black top cas. Anyway my question is why do I have to hook up my lab top and erase my p0340 code every time to start my car. I did everything right wiring is fine. spark plug wires are hooked up fine I did the install correct. My car runs great but It will not start unless I erase this code first every time I want to start. Can someone please help I'm really confused.
