phantom_19
- 410
- 2
- Oct 13, 2007
curacao,
South_America
Hi
I recently swapped out both my master and slave clutch cylinders. I measured the stock master cylinder pushrod and duplicated it. So it should all be stock.
After bleeding the clutchlines a few times. The pedal still has about 10 cm travel. I looked under the dash and noticed that the clutch pedal does not work right away. When I push it 10 cm down,THEN the master cylinder starts moving.
On my 1G n/t the clutch pedal is hard all the way down. N/T activates the pushrod right away. But on the turbo car it has to move 10 cm down first to push the rod. Is there something wrong with the pedal?
Also when I push the clutch pedal all the way down, it does not activate a small sensor that is down there. It should activate it with the small pedals. I think its the safety starting switch.
So why doesn't the clutch feel firm right away? I adjusted it right. Could the pedal assembly be bad?The slave cylinder has minimal travel.Car does not go into gear when i tried
