EclipseOwner95
20+ Year Contributor
- 704
- 10
- Oct 16, 2002
Jacksonville,
Florida
Ah, gotchya, runnin open turbo, ya you would see generous gain over the restrictive stock exhaust doing that, does no good dumping all that hot exhaust gas on the alternator, but most def would free up hp over stock. And yes basically as you said, you would see the same results from a full 3" exhaust as disconecting it.
I didn't say I was running open turbo, there is a factory O2 housing bolted to the turbo, meaning the exhaust dumps downward under the car. I'm sure it does raise under the hood temps, and probably not the greatest for the turbo, but its a throw away 14b, and I've got a lifetime warranty on the alternator.
