mikyrc
- 197
- 4
- Nov 18, 2003
Spain,
Europe
So doing this will allow full use of my headlight up/down switch, and will also keep my foglight function?? Foglight function is critical, as 90% of my lighting comes from my fogs.
Yes
Also, could you give a brief description of where these wires are inside the car? Thanks!!!
The chiclet and its wires (#2) are behind a plastic cover on the right side in the passenger foot area (next to the foot door light). You have some pics on this thread. And I'll put a schematic so You can see it.
For the #1 wires You should follow the harness coming from the light switch on the steering column area.
Also, this may be a bit of a noob question, but I'm guessing the letter abbreviations next to the wires designates the wire color. Is this correct? If so, what would "GW" be? Green and white? I am by no means a noob when it comes to electronics and schematics, but I dont deal with automotive wiring diagrams very much.
Yes it's the color code.
Look at that schematics:
