Ebay Exhaust New???
You have to check and see if the hangers are in the right place. measure the stock ones
Make sure it is for an AWD. I know it probably is considering it is advertised for a GSX, but it does not hurt to make sure.
I have a SRS on my GS-T. It rattles at idle. I believe that is because I connected the hangers to the bushings under the car correctly. When I first got it, it made no noise while the hangers were attached to the middle of the rubber bushing/hangers.
If it for an AWD, then it should fit perfectly.
I used 2 different ebay brands and they bolted right up. I dont think youll have a problem
