turbodsm18
- 675
- 4
- Jan 26, 2005
816/417,
Missouri
I dont post much on here but I think this would be appropriate to post. Over the last 1 1/2 years, myself and 417 Motorsports out of Springfield, MO have been building a 1989 BMW 325i with a stock 4g63 (6 bolt) short block. If you are a member on DSMLink forums, my build thread can be found over there.
So we drove the car out to the track tonight, dont own a trailer and dont plan on it, and made 4 passes with the car. Heres the rundown....
Car: 1989 BMW 325i
Engine: Stock 6 bolt shortblock - NEVER BEEN REBUILT!
Head: Unported 1g head, Kiggly springs, Kelford 280/276 cams
Turbo: BW S366 .88 AR T4
Transmission: TH400(RWD 3 spd)
ECU: Ecmlink v3 - Huge THANKS goes out to Tom and Dave at Ecmtuning for the support!!!!!!!!!!!!!
The car is on 33lbs of boost, E85 Fuel, and is Driven to and from the Track(about 25 miles each way)
First pass, got completely off the throttle in 2nd, and got back in it and ran it down the track.
60FT: 1.37
330FT: 3.90
1/8th ET: 6.06
1/8 Mph: 106 mph
1/4 ET: 9.80
1/4 Mph: 131 mph
Second pass, Barely peddled it off the line, and then ran it out the back door.
60FT: 1.36
330FT: 3.96
1/8th ET: 6.09
1/8 Mph: 115 mph
1/4 ET: 9.42
1/4 Mph: 142 mph
Third pass, Finally got a clean pass, but i think i let out just as I crossed the line
60FT: 1.38
330FT: 3.86
1/8th ET: 5.96
1/8 Mph: 116 mph
1/4 ET: 9.26
1/4 Mph: 144 mph
Fourth pass(Record pass), actually turned the boost down on the line to try and get the car to plant the tire. Worked and the car went straight.
60FT: 1.37
330FT: 3.83
1/8th ET: 5.91
1/8 Mph: 117 mph
1/4 ET: 9.19
1/4 Mph: 144 mph
This is now the STOCK SHORTBLOCK RECORD!!!!!!!!!!!!
Ill get some pictures up of the slip and Im gonna try and round up videos from tonight at the track! The car has more in it, just not enough time in the night to make more adjustments and passes.
Pictures of the car itself...
Like i mentioned, ill get more pics up after I get some sleep. Its now 5:35am here and I have been up all day....
Timeslip.....
-Kevin-
Car: 1989 BMW 325i
60FT: 1.37
330FT: 3.90
1/8th ET: 6.06
1/8 Mph: 106 mph
1/4 ET: 9.80
1/4 Mph: 131 mph
60FT: 1.36
330FT: 3.96
1/8th ET: 6.09
1/8 Mph: 115 mph
1/4 ET: 9.42
1/4 Mph: 142 mph
60FT: 1.38
330FT: 3.86
1/8th ET: 5.96
1/8 Mph: 116 mph
1/4 ET: 9.26
1/4 Mph: 144 mph
60FT: 1.37
330FT: 3.83
1/8th ET: 5.91
1/8 Mph: 117 mph
1/4 ET: 9.19
1/4 Mph: 144 mph
Timeslip.....
-Kevin-
