help with 98 ecu flash
alexrey09
Nov 30, 2008
jacksonville, Florida
hey guys im looking for some one with experience on ecu reflash and the cable to do it am not looking for free help ill pay 4 ## time n labor!
i just done a 2g awd 6bolt swap and its time for tune
any body know a good DSM TUNER?
go check out "first flash ecu" in the search forums. they have alot of info there. everything from what u need to get it tuned. i too am having the same problem with mines. trying to get it to defined my ecu rom but no go. check out that page and you will have somewhere to start.
If you still need help, my Tuner knows ECUFlash, hes tuning my car with it.
I am running Flash but I am a real newb with it. I have spent countless hours reading every thread, page, post and comments about it and I still don'thave it down yet.
First thing is you really can't put a tune on the car until you have your fuel taken care of. Also ALL boost leaks, and exhuast leaks have to be completely resolved. Do you have a wideband? I think I can help you get a base tuen, but Jaxness has the person in town to get it really dialed in.
Ill have to jump on this as well - I have a 1995 Eclipse GST with the following mods needing a tuner in JAX as well.
*CSF Radiator
*Manual Boost Controller (replaced as of MAY2012 with NEW one – pink ) $17.98
*255 lpf Walboro and 750CC Delphi Injectors - $355
*Universal Polished Aluminum Coolant breather tank - $60
*Polished gunmetal spark plug cover - $40
*AEM Air Fuel UEGO 02 Wideband 6-in-1 Gauge. Digital Gauge with Sensor - $168
*H&R Lowering Springs
*Balance Shaft Delete
*Vacuum Line Deletes
*Black Top CAS
*Short Throw Shifter
*Greddy Turbo Timer
*EvoIII 16g Turbo with no shaft play
*SS turbo feed/return lines
*Injen Intake
*Greddy Type RZ BOV
*MeganRacing Turbo Back 3" Exhaust
*VRSF Short Route Front Mount Intercooler
*VRSF J-Pipe
*Mishimoto Slim Electric Fans
*Mishimoto Metal Slim Fan Shroud
*Eprom ECU
*PaceSetter Tubular Manifold
*Head work including oversized valves (3mm).
i have been looking for a few weeks but people that do this kind of work are very hard to reach, i meet this guy from http://www.ocalatunerperformance.com/index "matt" he is a very cool guy, stand behind his job and always there when you need him!
he will be up here next Saturday 12 of may so if any of you guys are looking for a full custom tune you better jump on it!!
he offer Tuning services for many applications.
AEM, Ecu-Flash,DsmLink
Hondata,K-Pro, MegaSquirt
Emanage,MoTech,MicroTech
HalTech,Apexi, SubiScan,EvoScan
