dberry
- 32
- 0
- Apr 9, 2012
Clarksville,
Tennessee
Okay so I have pulled off my transmission 2 times, first time was to put the correct fly wheel on it after that the clutch was 100 percent fine and I did notice my through out bearing was dry but I figured if its not broke don't fix it, after about 2 days I was at a stoplight and I couldn't get it in gear, so embarrassingly enough I started it in gear and rpm matched my gears to make it home, 2 time I dropped the transmission I replaced the throughout bearing thinking that's what went out but I noticed the old one was still fine... I then looked at the pressure plate no bent fin or anything so I out it back together, same issue again.. won't fully release the clutch, I looked at the space cylinder and it works from what I can see properly, it pushes the clutch fork about an inch, I checked the fluids and everything looked fine, I was thinking maybe I bent the clutch fork, I mean I did get on the motor pretty hard right before my problem initially happened, any ideas????
