joeberman01
- 0
- Oct 27, 2010
Laveen,
Arizona
Hey guys thanks in advance for any help you can provide. Ok so I finally finished getting my new 4g64/63 hybrid I have link v3 lite. The ecu is showing power and I can connect. I am using a green top cas and I'm almost certain I did the wiring correctly. I believe the plugs are getting a spark but the injectors are not getting a pulse. I bought the harness I am using for the cas so it should be good. I have been reading for hours and am totally lost. The headlights, turn signals, interior lights, and various other random electrical work but the cluster does nothing buy show when the brights are on. the fuel pump is absolutely working so are fans when enabled in link. I had originally had the crank signal wire hooked into coil pack since they were the same plug and I fried a set of coil packs but I replaced them back with the spyder gs coil pack and like I said its getting a spark. I am tearing my brain out here please any insight would be so appreciated. I just want my car to start. Oh yea one last thing the starter solenoid is not getting power when hooked up key won't crank the car but it does when I have it hard wired and touch the battery.
