90awd4g63
- 73
- 2
- Aug 20, 2005
Augusta,
Georgia
Straight and to the point.
CAR: 90 Talon TSi
PROBLEM: LOTS and LOTS of white smoke from exhaust and turbo
EQUIPMENT IN QUESTION: Turbonetics ball-bearing 60-trim
SYMPTOMS: The car started smoking like crazy. Figuring it was the coolant line on the turbo, I removed the coolant lines and started the car. Still smoking. Needless to say, I didn't have issues with mosquitos while the car was running. As it poured out of the exhaust, I went to the front of the car and noticed smoke from under the hood. I'm getting fluid leakage where the "hot" side bolts up to the downpipe. I did a compression test, and it's 150 across the board. I started to remove the turbo to slap on a 70-trim, because I thought the turbo was gone. As I removed everything I could to get the turbo off, I noticed there is no oil/coolant in ANY of the piping. No blown gaskets. No shaft play in the turbo, BUT my oil return line was kinked. It was bent where the flow of oil wouldn't stop but be hindered some. Could that cause the problem???
NOTE: Some of the "wet" areas in the pic are not the leak. It's WD-40, where I was trying to remove bolts. The circled area is where the leak comes from.
CAR: 90 Talon TSi
