need help
95_GSTBOOSTIN
Feb 24, 2012
Kalamazoo, Michigan
Are the fwd 2g 420a speed sensors interchangable with the 4g63t ones? Also will a n/t 2ga fuel level sensor work in a turbo car?
The only reason I'm asking about the fuel level sensor is because mine is bad and I tested the gauge and it works therefore its my fuel level sensor that is bad. I just want to have a working gas gauge again.
Sorry i thought you typed fuel saver instead of fuel level.
It should work out of a gst.
I have a 95 gst auto and the junk yard around here only has gs models. That's why I wanted to know if one out of a gs will work in a gst.
