WES_393
DSM Wiseman
- 3,815
- 81
- Jun 6, 2011
Colo Spgs,
Colorado
For quite some time I kept reading that it was impossible. The block is mirrored, the head wont fit, the trans wont fit, etc etc. Well, I recently picked up a 4g64 engine block out of a 2003 Mitsubushi Outlander which I beleive is the same engine as the 3g Eclipse RS. This is not a "Will it work?" thread, this is a "It WILL work" thread. So far at least. Yes, it's tranverse mounted with a mirrored head in the Outlander. However, the block itself is not mirrored, it is flipped. Here's my progress so far.
Casting tag. It is indeed a 4g64 (I checked the stroke as well). Some of you more internet oriented people might be able to find out what the other numbers mean.
Here's the bare engine block. This is the "back" of the engine which will be the front in the DSM. Notice the counter-balance shaft is in the same spot as the 2g 4g64/4g63 engines. The knock sensor is also a nice addition so long as it doesn't get in the way of the water pipe.
The top of the block. As you can see the pistons sit down about 1/8" or so from the deck. This might give the engine a lower compression ratio with the DSM head which would be ideal for those looking to use the stock block. However, from my calculations, a 86.5mm piston with a -12 dish will give this engine a compression ratio of about 9:1. That would be a good start for a higher comp build. Personally, I might try to get closer to 10:1 to make this a very high comp turbo build. Also notice that the oil galleys that feed the head are in the correct spot.
Here's the big "issue" with the newer 4g blocks. The 2g DSM head supposedly wont fit. Well, see for yourself.
Exhaust ports on the front.
Intake on the back.
Cams are on the correct side as well.
Bolt holes in the head line up.
Oil drains line up as well. The additional holes will need to be blocked just like the 2g 4g64 block.
Here's the timing components. As you can see, it's nearly identical to the 4g blocks found in DSM's. I'm not sure if the motor mount can be left alone or if a DSM mount needs to be installed, but that's next on the list.
Here is the only problem I have run into so far. The block bumps out around the dipstick so the Outlander oil pan must be used. This is a minor issue though as an AN fitiing could be installed on the oil pan for the turbo drain.
But I'm sure your thinking "How are you going to mount it?". If you remember, the 2g trans has 3 of the motor mounts on it already. As long as the 2g trans bolts up, it will be completely possible to mount it in the DSM engine bay. Well it's a narrowblock and has the exact same bolt pattern as the 2g 4g63/4g63 engines. The starter in the Outlander is in the front, so once we flip the engine it will be on the back in a DSM where it should be. So it looks to me as if it will bolt up to a DSM turbo trans with no issues.
So far this engine block will work. Like I said earlier, my next step is to compare the engine mount to one from a DSM. If it's possible even with minor modification, I'll begin building this engine and noting the pro's and con's in this thread. I'll also be looking into things such as power steering bracket, alternator mounting, carrier bearing mount (which I think I've already found), and other important bolt-on parts like those. It's also important to note that this is probably not the same as the 3g 4g63 and I'm also not 100% certain it's the same as the 3g Eclipse engine. However, I personally don't see that the 3g 463/4g64 block would be any different to build like this. But for now, lets focus on this one.
Intake on the back.
