arcuri21
- 47
- 0
- Mar 6, 2011
rome,
New_York
What size is your oil drain line? They may have made their way down being in those little pieces kind of difficult to judge the size but the paper gives a decent reference.
Edit: I got beat by a minute on that response.
could be some retainers? or a bracelet?
balance shaft bearing maybe
Turbo journal bearing; very worn.
OEM T25 bearings have a silver coating.
Beg pardon?Do you people even read the replies in these threads? Or do you just look at the title and picture(s) and reply? My God.
Beg pardon?
Beg pardon?
I believe that response was towards the other posters who were still guessing at what the OP's photo was of when you had already solved that mystery. I'm still interested to hear how the OP got the turbo to granade itself to that point.
SkyGrowsCold nailed it on the head. I meant to point out to the others you had already figured it out. I must not have been clear enough as to what I meant, sorry about that.
Alright- nobody else asked it so I now feel obligated.
How the hell did you kill a T25 bad enough to put journal bearings in the oil pan in 20k miles or less?
Looks like a turbo bearing somehow ended up in there. Makes you wonder if there was really 20k of original miles on that motor? Good luck.
I bet that old 60 year old had a boost controller and turned the boost up to 25psi and before she sold the car she took it off.
Did you tried to put in the fire? there might be elves symbol that will appears?
Did you try*
Journal bearings? Crazy that they must've fallen down the drain tube. I was going to say, based on the first few replies, there's no way that got into the oil pan from swapping cams.
Luckly you cant run 25psi on a t25.I bet that old 60 year old had a boost controller and turned the boost up to 25psi and before she sold the car she took it off.
I've found treasures in my 4G63 12mm socket in the the no 4 cylinder intake, wire cutters in the power steering cross member, $$$ under the spare tire.
I like tearing my car apart because I never know what I'm going to find next! (Or discover what is missing...)
