- Thread starter
- #26
ty92dsm
- 189
- 1
- Dec 15, 2010
columbus,
Ohio
O ok my bad I tthought there was a way to figure that out.
Thanks for the good info man
What is the calculation to find what psi would be 30lb/min on a 16g?
Because the only reason people use a GM MAF these days is so they can vent the BOV.
Now that you mention it though, I can't remember seeing a GM MAF in draw through either.
I use a gm maf because it meets my airflow metering requirements, and i don't have to redo all of my tables in my ecu whenever i change my setup, which i do often. I've run speed density, and didn't feel as if my cars performance transcended to some higher level.
I dont believe any of that is true.
Wiki ftw
The Manifold Absolute Pressure sensor (MAP sensor) is one of the sensors used in an internal combustion engine's electronic control system. Engines that use a MAP sensor are typically fuel injected. The manifold absolute pressure sensor provides instantaneous manifold pressure information to the engine's electronic control unit (ECU). The data is used to calculate air density and determine the engine's air mass flow rate,
What isn't true?
Well now I am confused on which one would be best for me. The GM MAF seems to be easier if you change a lot (which I probably will). But then I like the way SD works and you don't have to have the big ugly blowthrough.
I was commenting on the fact that map sensor meters air similar to maf.
A MAF sensor measures airflow; a MAP sensor has no clue about how much air is flowing.
The end product is the same (a specific amount of fuel injected), but the processes used to get there are quite different.
OP:
MAF = Set it and forget it, but somewhat sensitive to weather changes.
SD = More stable, but must re-tune if something changes to affect the volume of airflow (cams, intake, exhaust, etc).
Need to know if I can just run SD with link and no MAF?
I wanted to bring this back to life because I was wondering about the same thing. I am leaning towards SD because I want to build, tune then be done with it. Need to know if I can just run SD with link and no MAF, or should I look into an EVO MAF?
Its the best way to tune)
you just wire in your SD sensors. leave the mas plugged in. drive around on a log. then run the sdcombinedratio{i think thats the right one...} tool via link and it sets the table up based off the mas signals.
Sorry, But I am in the same boat.
I just don't get it, you said to wire the SD in and leave the Mas plugged in?.
It means to split the Baro in two?, one for the Mas and one for the SD?.
Sorry, I just trying to get this all straight up in my head.
I think he meant maf, that way you have most of your stuff already set and your car is already cruiseable, then you are just making small adjustments. instead of when you first get ecmlink and plug it in and have to adjust everything at once to get the car running right. atleast that is what I believe he means as a guy on ecmtuning told me the same thing. my tune is stable at best so I am just starting from scratch putting my wide band and sd in this weekend. no more limping home when a coupler breaks free.
Yes, you are right, The only confusion that I have is, If the MAF and IAT plugs in the same line (Baro), to get the MAF Dial and copy for the SD table.
blowing an innercooler pipe or having a boost leak doesnt prevent you from getting home.
