laserspeeddemon
20+ Year Contributor
- 6,717
- 61
- Jul 26, 2002
Fredericksburg,
Virginia
OK new question. Anyone body thought of running the cables through the shifter cable bushings. I thought it was pretty smart. Wires go straight through the bushings. Then goes off to the right side to keep away from the main engine harness/ECU. It follows under the center console under the rear seats and then off to the passenger side where. Here are some pics.
(In this photo the two lines going down are the shifter cables. The one going kind of up is a power cable).
It's not complete (obviously), but I like how the shifter cable bushings keep the wire(s) from touching the metal. I plan to run two 4ga wires through as well and put the power distribution box under the dash in the center.
