1992_Talon_tsi
- 384
- 2
- Dec 20, 2009
MIAMI,
Florida
I have a problem on my 1g, for some reason injector 2&3 are not working i switch them around and even test them and theyr good. Now i checked to see if there was any short between resistor and injector but signal appears constant. The other thing i could think off its either a short between the wire that grounds on the ECU and the injector or a bad ECU. My problem started this day i was on my way to work and the car just randomly started to sound like if it was running on 2cyl after that day iv replaced spark plugs, wires, coil pack but then notice injector 2&3 were not working, i dont have any check engine light on and im going to provide some pictures of my ECU.
