grdeclipse
- 34
- 0
- Sep 10, 2007
Meridian,
Idaho
Okay fellow dsmer's, My clutch pedal is squeaking, and is driving me insane. I have tried spraying wd40, lithium grease, and penetrating oil, but of coarse nothing has worked so far. I highly doubt this, but is there a grease insert on the clutch and brake pedal shafts that will grease up the pedals? Has anyone else had this problem with there pedal and if so what did you do to fix it? any suggestions would be greatly appreciated. Thank you!
