Merrifast
- 0
- Dec 24, 2011
Indianapolis,
Indiana
Hi everyone, I am a probationary member so I am posting this question here in hopes someone will find it.
First off I would like to state that I just bought my car one week ago, and I have already put a new alternator and battery in the car.
The problem is that the car will fail to start on some key turns, and on others will fire right up. When it does fail to start i can hear a hissing sound coming from the middle console (near where the ECU is located... could be the ECU itself). While driving the car on a full battery lights are strong, CEL lights are strong. while driving on half full battery lights are dim most of the time, but then sometimes will become strong for a few minutes then go back to dim. This indicates to me that the charging system is intermittently working. While driving on a near empty battery every CEL light will come on, car will try to die unless I drive WOT, or try to hit potholes, then the charging system will kick in for a few minutes. I am aware that all CEL lights being on indicates that the ECU does not have enough power, and car will die, as it did.
All of these seem like symptoms of a bad ground. I have bought new ground cable to be installed tonight (Christmas Eve), also I have noticed that the 10 gauge (i believe it is 10 gauge, if I am wrong please let me know) wire that from the battery to the fuse box seemed to be slightly burned as picture below indicates:
I then proceeded to take apart the fuse box to investigate if any of the other wires appeared to have burns. After fuse box bottom case was off I noticed another weird wiring issue, however I am not sure if this is STOCK: there is a 14-or-so gauge wire coming off of the main 10 gauge power wire (from the battery) that goes to one end of the AC Fan. Should this AC fan be getting power directly from battery, if this is not normal please advise where this lead should come from? Here is a picture of the wire:
If I cannot find a gremlin in the wiring, I will resort to buying a new ECU.
I appreciate the forum, and wish everyone a Merry Christmas!
-Alex
-Alex
