FS: 1G Fluidyne Radiator - $150
Module Unknown
20+ Year Contributor
557
Nov 27, 2001
Elk Grove, California
I have a 1G Fluidyne Radiator for sale for $150. Located in South San Jose.
Picked this up a while back but never installed it as I decided not to use a 1G radiator on my GVR4.
I'm having a black Friday sale! $100 for a near new 1g fluidyne radiator!
Anyone? :)
Would this fit a first gen Evo?
It would not be a simple drop in replacement. It's shorter than an evo I radiator and does not have a filler hole. I'd suspect, much like my situation with the GVR4 that you would need a 1g thermostat housing.
I've decided not to use this on my GVR4 for that reason. In fact, I've found that an evo I, II, III radiator is a much better fit for the GVR4.
I plan to buy a koyo. Part number is KOYO R030561. I'd look into that as a replacement for your application if you want an aluminum radiator.
What do you mean by filler hole?
Anyways. I was thinking of getting a shop to make a custom one probably come spring time. Thanks for the tip on the Koyo, I will check it out!
He means the radiator cap is on the water neck and not on the radiator. I was barely able to squeez the Koyo R-Core into my GVR4, but it does fit. When I ran the Fluidyne on my Galant I had to build a spacer for the thermostat housing/water neck so that the radiator cap was the highest point on the cooling system.
Yeah, that's what I meant. :p. Thanks.
I'm curious, how tight of a fit is the koyo, and more specifically, what part/area was a tight fit?
I have a FP3052 setup with the wastegate recirculated (FP o2 housing) and the recirc pipe is the closest part. It clears by about 1/4-1/2" at best. There's some room on the compressor side to go a little larger, but not much. Another thing to note, is the the Evo 3 radiator does not have provisions for the thermal switch (fan switch) so you will have to get one welded in (what I did) or figure something else out.
I'm aware of the need to weld in a bung for the thermal switch, and I'm running (will be very soon) an FP68HTA, so I guess I won't have to worry about space when compared to you since I won't be any larger than the stock turbo setup's footprint.
Thanks again! :)
