- Thread starter
- #76
Calan
DSM Wiseman
- 7,251
- 363
- Jan 16, 2007
OKC,
Oklahoma
I can see how a faulty CAS would effect fueling, if the ECU was seeing a lower RPM value than actual RPM, then the Speed part of the Speed-Density calculation would be off.
Yeah... but it's damn strange how it affected such a narrow pulse width and created that spike. And the logged RPMs were solid and matched the tach; in fact the only symptom I had at all was crazy retarded timing (and the resultant high EGTs) for no apparent reason...but even that didn't show up until later.
Sure looks like that was it though. Every time I run the CombinedFT tool (or work on it manually in open loop), that area at 2500 keeps smoothing out and blending into the 3k column like it should.
