crash bar
I assume DSM's have a rear bumper pad...most cars do. But seriously that's not the smartest idea to remove it if you don't HAVE to. If your that worried about weight, take the spare tire out! Either way it's not going to make any kind of difference.
yes they have a rear bumper.. but I'm with the guy above me, its not worth the weight loss in my opinion.
Why would you want to put your car and yourself at risk to save a few pounds? No weight reduction is worth my life.
I did some work on my sisters galant a few years ago. They actually do use styrofoam pads. But they have a metal beam behind that which provides the integrity. The styrofoam is for support on little parking lot taps, allowing the cover to flex a little.
Personally the amount of material that would have to come out of my crashbeam when I installed my fmic was just too much to even consider cutting the crashbeam. With it being cut I seriously doubt it will be as near as effective as it was originally.
eh? just to make sure were on the same page were talking bout this right:
because I could swear that thing is much more solid and feels like metal but maybe I gotta double check.
GALANT. Don't ask me why for that model they configure it different. Just spittin info that there are some bumper supports that have styrofoam
....as stated....I was just informing that there are cars out there that have styrofoam. Not every car has a fiberglass bar.
IIRC, the 2gs have a stryofoam padding between the bumper cover and the fiberglass bumper to help support them and for light bumps. Its been a while since I have taken a 2g front bumper off that has never been off before. They are often not put back after the bumper cover has been removed.
That is correct. The 2g's have a bumper reinforcement (fiberglass, which is pictured above) as well as a bumper core (styrofoam piece). The bumper core just lays on the front face of the reinforcement which little tabs that go into the two small side recesses you see. It is held in place by the bumper cover as it doesn't stay by itself.
Eh?? The point is... it's still there just in case.
