SBstar
- 3,038
- 123
- Jan 1, 2004
Jackson,
Michigan
Congrats Dave! Got that monkey off your back in style! 9.6 with a 1.83 60 ft is mind blowing. Can't wait until we see what can be done next year. Obviously you haven't had an opportunity on a well prepped track with proper temps to learn the launch with the new setup, only having a couple passes in! You get out there a few more times and you'll be back in the healthy 60 ft range and then we'll see some real magic!
As for the Batmowheel vs. HX40 talk, oh well, it's still a holset and it's still the first one to go this quick. I would still call it a budget build, just because all the parts aren't budget doesn't mean it's not a budget build, you apply parts as you can afford them. Certain parts that aren't considered budget such as the dogbox, end up being budget as it'll save you money replacing transmissions in the long run. When you're trying to go fast you're going to push the envelope by trying different parts and different things, people who don't like it can go run whatever they want and try for themselves. Keep up the good work!
