Kevin Jewer
DSM Wiseman
- 1,464
- 278
- Jul 25, 2002
LaRue,
Ohio
I've got until the end of the month, so about 4 more trips. If I can get what I want out of the 16g I plan to toss a 14b on if I can borrow one somewhere before the track closes.
I doubt anyone here cares, but I went to the last track day of the year. Ran a new personal best of [email protected]. Also had a [email protected]. This is done on 94 pump fuel with a stock clutch that was slipping pretty good. A good clutch and the car would easily run 12s as it is.
I said the same thing when I first started posting on this thread. You'll see a lot of 14b records talk but this isn't the "14b record chase thread", its the "14b drag race discussion". You and I are drag racing our 14b's and that is what this thread is about. Good times by the way! Traction must be nice
sorry to hear that nate, but it sounds like the best plan. Can't wait to see what that new setup does next year! I like the sounds of what you're planning, that explorer 8.8 rear certainly sounded more intriguing after hearing about the weight loss, any idea what that will cost you?
DSMlink can do dry shots too, I'd hold off on the AEM until you get everything working as advertised, then make that change by itself. It takes time to get used to the AEM and getting it working well, so it can be extremely frustrating if you're still chasing other issues with the car. Once you know the car is working well, any issues that pop up are likely due to the AEM and are easier to figure out and fix. That would be my advice as far as that goes. You're close to getting the working well, I think the switch to a dry shot alone will solve most of your issues.
Regarding additonal fuel, if a 14b makes 300 hp on its own, and you're adding 150 hp with the nitrous, you need roughly 50% more fuel. Anything ~650s and up should do it. I would certainly do at least 950s of course, you want plenty of extra room, but just wanted to pount that out. 1600s (unless they are the high z version) are another pain in the ass you may not want to deal with yet.
Good luck!
Time and money for sure!
On a good note, I have my car running again...finally! I'm going to pick up my wife from work and bleed the clutch then I'll give it a test drive. I set the base timing and started getting the airflowperrev's in check, pulled a bit of timing, and I'm going to be real cautious until I feel comfortable with this motor running.
