L train
- 0
- May 14, 2011
brownsville,
Oregon
ok so i have some bad idle surge i suspect its the isc or rather the wiring to the isc ( i have replaced everything so its got to be a wiring issue i have 0 boost/vac leeks) sometimes when i drive for 30 min or so it will idle just fine, but not always more often i pull up next to a car most likely a riced civic at a stop light and my car starts bucking from idle surge....not pimp
i looked in my book for how to test this issue and i ran in to what i think is some problems
the book says to check the voltage of the connector and that one pin should read batt voltage and others should read less than batt voltage
(with key on checking pin voltage on the isc connector harness side)
pin#1=0v
pin#2=12.43v
pin#3=0v
pin#4=0v
pin#5=12.46v
pin#6=0v
then it says to check the resistance between pin 5 and either pin 4 or 6
and it should be in the order of 30 ohm
pin# 5&4=0 ohm
pin# 5&6=0 ohm
so i had a buddy turn the key off and on so i could see if the isc cycles or not
it dose but not very smoothly. it sort of shudders into place
i check another isc i had from a known working motor and the same i get articulation but in a vibrating shuttering motion
so my question is this i guess where do i go from here? and what pins should read what?
pin#1=0v
pin#2=12.43v
pin#3=0v
pin#4=0v
pin#5=12.46v
pin#6=0v
pin# 5&4=0 ohm
pin# 5&6=0 ohm
