turbod95
- 0
- Aug 29, 2011
Litchfield Park,
Arizona
I just bought a 95 Eclipse GST the other day. The guy I bought it from said that all i needed was a ECU, So i went out and bought one. I put it in, and all it does it crank. I checked the compresion in the 4th cylinder and it had 125ish PSI. I know thats not normal. But the previous owner has done a lot of work. like bigger turbo, inner cooler, wastegate, cold air intake, I'm sure motor work. But there are some sensors unpluged. I'll put pictures up in a little.
My question is. How do i check for spark? and what else should I look for to try to get it started?
Are there spouse to be wires or plugs on the head?
