Spoolin4Ever
- 1,142
- 13
- Apr 24, 2005
Moses Lake,
Washington
Anyone know a quicker easier way to clean off the old head gasket?
You can user a razor on the block, but you should use a plastic scraper on the head, as it is made of aluminum and is softer than the steel block.
on a block I use the red and blue scotch brite disks from harbor freight. for the head I would just pay the $25 to have a shop surface it.
I found it at both oreilly and autozone, i think NAPA carries it too, it's in a green labeled can with white lid, about the size of a can opf spray paint..it burns skin and will hurt paint though so be carefull where you put it
