JMarion89
- 0
- Jun 29, 2011
Lakewood,
Washington
I have an odd situation going on, Just picked up my first dsm. It was already modded (probably a mistake) but the car ran ok when i got it. First off, cold starts are bad, have to start the car 5-6 times before i can give it any gas to keep it running (as soon as you hit the pedal it dies but if you dont give it gas it will die). Recently the check engine light came on and the car would idle at 15-17 and jump up to 20-21. the car still ran fine just acted goofy at idle. I went to drive my car to work, planning on checking the code at lunch and but on my way to work the light went off. Car went into a "limp mode", it idles at about 800. Theres an a/f gauge in the car and it said it was running lean, the car stutters and has no power. I have no idea how it acts under boost i just tried to baby it home. Tried to check the code but its just continuous blinks . Not sure where to start, I feel like im chasing a few different problems. Thanks
