Springtech camber ball joint
Guzman08
989
7
Jun 16, 2009
Valley Wide, Texas
Was wondering if anyone has used these camber ball joints before. Dont just say they are garbage because they are from ebay. Unless you have tried them and you know for a fact. Couldn't find that much information about them. They look like a copy of the spc ones. i really want to try them but i thought i could find out some info first
95-99 Eclipse Front Camber Kit Adj. Ball Joint 96 97 98 | eBay
I don't know anything about that brand, but the price seems very similar to other known brands. Just something to consider. Ingalls is trusted and available for significantly less it appears. http://cgi.ebay.com/ebaymotors/INGA...r_Truck_Parts_Accessories&hash=item3a6733e1e5
They'd likely work out as well as any other adjustable ball joint for our cars. Slight suspension interference with good adjustability that goes un-used. Might be expensive to replace.
Is there a reason you're not considering an eccentric bushing-type camber kit for the front?
I don't know anything about that brand, but the price seems very similar to other known brands. Just something to consider. Ingalls is trusted and available for significantly less it appears. INGALLS BALLJOINT FRONT CAMBER KIT MITSUBISHI ECLIPSE | eBay
Yeah the only reason i wanted the ball joint camber kits was the current ball joints on both control arms are torn and i just thought if i was going to replace them i should just get the adjustable camber ones so i can get an alignment. I never saw those Ibgall ball joints thanks for the link. Also the car was already dropped and im not sure with what springs but how could i know how much camber i need without going to an alignment shop?
