mnetwork
- 1,017
- 2
- Feb 25, 2006
New Milford,
New_Jersey
I have a built motor with 7bolt block, Mitsu MLS head gasket, Wiseco 8.3:1 (.020 overbore) pistons, stock valves, and BC272 cams. The motor has a few thousand miles on it now andf I just did a compression test. All cylinders were tested twice and all tests were done with motor > 183 degrees and with throttle WOT.
My numbers were:
Cyl1 - 165
Cyl2 - 172 (little lower than the 175 mark)
Cyl3 - 165
Cyl4 - 165
Was wondering what I should make of these.
My numbers were:
Cyl1 - 165
Cyl3 - 165
Cyl4 - 165
