hypergenesis
- 890
- 1
- Oct 21, 2010
Tracy,
California
So I am running into a dilemma now with what to do next with my 96 Gs-T. Currently, power wise, I only have bolt-on modifications. 3" Turbo Back, Intake, FMIC, BoV, Ignition etc. I just purchased V3 with an epromed ECU and a Wideband to come in. Now what I am coming down to is what to do next, I am about to go purchase some 850 CC injectors and start getting the prep work and mods for the MHI16g I want to end up putting in this baby.
But with maintenece and from what I have read theres more prep work to be done for it. From what I read when upgrading a turbo generally speaking, its best to replace the headgasket due to more pressure and strain on the engine. Now I was wondering would it be a good idea to just switch out the headstuds to some ARP headstuds?
Let me remind you its a 7bolt block with 150k Miles on it compression is good though, all the miles were DD miles I bought the car from a dealer and literally from everything I have done so far I can tell nothing has been touched unless someone knows how to make parts look used after being replaced haha.
Another question I have is how important is your wheels being cambered and aligned? Like I understand the Tire wear and what not but how vital is it towards the rest of the car. Currently, after dropping the car and adding new wheels, the back wheels camber a whole lot and I have already done a camber kit to straighten the back ones a bit but they still slant a good 5-10 degrees or so. Just curious on the amount of strain last thing I want to do is hurt my baby.
Basically What I am asking is what should I invest into next? I am at a stand still towards suspension or engine mods and getting everything ready to support the new turbo or fixing the current problems with my suspension aka (outer tie rods, strut mounts, rear Sway bar), OR go towards buying Injectors, Fuel Pump, AFPR, Turbo.
Thanks all for the help
Armin
Armin
