highrever
- 45
- 0
- Mar 14, 2011
thompson,
MB_Canada
I need some help with this timeing belt install I am a first timer. To start off i have replaced the balance shaft belt no problem, water pump and new tensioner pulley and idler pulley. So the problem im having is when I go to tension the belt through the tensioner pulley, the cams move out of time. So i proceed to remove tension from the belt and line everything up again crank, oil sproket etc. Then i try putting the exhaust cam off one tooth like vfaq's tells me to do, with everything lined up on the correct timing marks. So i again proceed to tension the belt with the pulley and great the cam marks line up so i tighten the bolt on the tensioner pulley, then i lossen the tool that pushes on the tensioner arm and when i loosen that the cams go off of their proper alignment. This is getting very frustrating im loosing patience here. what am i doing wrong? I keep re-doing each step over and over and i get the same results everytime. Please help me
