- Thread starter
- #26
Morales92
- 223
- 38
- Jan 15, 2009
Anaheim,
California
$600 bucks for an engine craigslist already built with Je pistons and eagle rods, hmm i kinda of want to buy it but scared.
well if anything i just want 8-10psi not looking to go that fast as my car is automatic. so i just want 8-10psi safely without breaking again. I would think that piston cracked cause of how many miles it had. i bought it used at 130,xxx miles in 2005 didnt start using it until 2007 and before the car was used by a company to travel to san fran, las vegas, arizona so it had a lot of highway miles on it.
it cracked where the rings are at.
All stock 420a head gaskets are 3 layer.
One thing you have to keep in mind, if you build the motor thats all fine and dandy but if you still have an improper fuel set up you will blow it again. The safc is almost useless on a 420a eclipse thats boosted, think about how the safc works. It modifies the Map signal going to the ecu and bends it to make the ecu squirt more fuel in it. Well when the 2gnt ecu see's positive map pressure it cuts fuel because it doesn't know what to do, the only reason people used to use Safc's on the 2gnt is because they where running stock turbo injectors and an FMU/SFMU and couldn't idle the 450cc injectors on the stock ecu. It was a hack and it did work, but it didn't work well. For the price of the safc you could run MS and if you can wire the safc in then you SHOULD be able to wire in MS. People get scare about it but its really all elementary stuff. If you think MS is still over your head then invest in portfueler from Hahn, I know there where/maybe still be quite a few of them for sale on here or 2gnt because a lot of people are going with MS now. So in short, a stock motor can handle the power you are trying to pump through it, but you need to figure out your original problem or it will happen again, even on a built motor. Forged pistons/rods doesn't mean you can do what you want and your motor will be fine...which ever way you go good luck!
^ Whatever happened to this? I think head gasket and rod talk is kinda a mood point if you are still running lean. I think you said you had a 12:1 FMU and you are running a walbro 255 right? Also I assume you have the missing link or FCD? If you arn't changing anything with your fuel setup I would suggest adding a wideband so you can watch your air/fuel ratio so you don't have to go through this again. Good luck
