BayState300GT
- 67
- 0
- Aug 22, 2008
Allston,
Massachusetts
Is the stm tank to rail kit worth it? My car is daily driven, 950cc injectors, gt35r, wiesco/ eagle, 272's. Also is it easy to install? Thanks.
I "fixed" the sending unit completely with the link i posted above. Here it is again check this out http://www.dsmtuners.com/forums/articles-engine-fuel/254501-high-flow-fuel-set-up.html
All was well until you used a worm clamp on a fuel line. Never do that. Get the special clamps for fuel lines that don't chew the rubber as you tighten.
Can we get some pictures or a how to on installing an AN fitting in the fuel sending unit?
I dont see the point of the kit if it attaches to the stock line as that will be the restriction point. It would make alot more sense if the lines started at the sending unit for max flow... not knocking the STM kit in any way though, I plan on getting one myself
