DSM IN MN
Supporting VIP
- 705
- 23
- May 17, 2009
Wadena,
Minnesota
My friend and I have been working on his Eagle Talon ESi since around 6:00 PM yesterday.. Ten hours later we are still here..
We are attempting to turbocharge his car. We have the oil return tapped in the oil pan and EVERYTHING else.. We just need to know how to remove the "green" bolt to use as the oil feed line..."oil pressure sender"..
Yes, I have searched. And no, there is not green bolt or anything of the like. There is a mis-shaped bolt though, with a black connector on the end of it.. We have tried to get it off and all this black connector does is spin (bearly)..
We need to know the size of said bolt so we can finish this project..
Some help would be appreciated..
There is no way in hell I will be able to get the sending unit, sensor and all off.. I tried 15-20mm wrenches and no matter what one it was, there was not enough area in the alloted room of the engine-bay.. (Yes, I was doing it on my back under the car.. It still will not work..) I need ideas/information as to how to finish this car...
This is someones DD vehical.. They need it and my dad needs it out of his shop.. Come on people...
