zrsnopro97
- 91
- 0
- May 15, 2010
indianapolis,
Indiana
Hello, this has probably been posted before but i used the search and didnt come up with much.
When im cruising along in gears 3,4, or 5 and let off the gas completely, i get a pretty loud rattling noise coming from the front end. If i push in the clutch, or touch the throttle, it goes away. Its not the exhaust or anything banging around...
Anyone else have this problem? I just changed the transfer case oil and it only took like half a quart? Is this right? The problem was there before and after i changed the t-case oil...
Any help is appreciated.
thanks
thanks
