wtb local motor, cheap 1g
tsi4g63dohc
204
Feb 22, 2010
martinsburg, West_Virginia
lookin for a cheap runnin motor with good compression and no leaks , lookin to spend couple 100 bucks , located in gerrardstown wv, could drive to winchester or hagerstown to pick up , thanks , number is 304 995 4969, if you have just block the was runnin ill take that needs to be already put together
LOL what happened
rods a knockin ! took off the pan to check the damage and cylinder 1 had a bit of rod play and scratched the crank bad, then took off number 4 and the bearings were copper and broke in half ! im planning this rebuild but need something soon to put in to drive ! just found a motor in walsboro for 700 , 80,000 miles on it tho, perfect compression the guy says, he pulled it due to major rust issues ! hes willin to pull the pan , timing covers , and valve cover if i want
