4G63Crossfire
- 39
- 1
- Jan 13, 2011
Huntsville,
Alabama
I am swapping a 4g63 into my 2004 Crossfire using an adapter from Bill and a TH350 Tranny. I have been posting the build on projectzerog but i thought I may get more answers to questions over here. Will an Evo 8 manifold and turbo fit this rear wheel drive application? I'm not using the coolant pipe that goes from the water pump and behind the turbo because my inlet is up front. I'm not sure if that is the mounting issue or if the block is the interference issue.
Here is another pic, I am going to have the intake manifold modded so that the throttle body is up front too.
