Engine wont sart 94 gs
dannigirl4g63
Jan 20, 2011
Spokane, Washington
my cousin sent me this message and im out of ideas please help! its the 1.8 sohc motor
i got a 94 mitsubishi eclipse gs. the water pump was smoked and as i was getting to it found other things wrong with it. fixed all that. then ran into timeing issues and found the timeing notches on the crank and cam gears were off. got it all figured out and put back together. now the thing wont start. im getting spark, perfect compression, fuel, air, ignition timeing set just right, battery is brand new and so is the starter. its driveing me nutz .-.
Are you sure that the injectors are actually opening?...you can be getting fuel all the way up to the rail but the injectors aren't opening so it won't start....just something to look at
Hit it with starting fluid and see if you get it to fire. Starting fluid will start pretty much anything as long as spark and compression are present. This will help you determine if the issue is fuel- or ignition-related.
hmm.....this is weird
You have to be looking over something ....if everything is perfect its not possible for it to not run
