talontsiboy24
- 869
- 3
- Mar 28, 2009
60457,
Illinois
These are the mods on my 92 talon tsi awd its tuned at 19-20lbs of boost. what do u think i should i add or update? ask me some questions to if you like.
ENGINE
Stock pistons
Stock rods
ARP headbolts, mainbolts and rodbolts
MLS headgasket
Filled front and rear engine mounts
TURBO,INTAKE,EXHAUST
MHI Big 16G turbo with clipped turbine wheel
HUGE 3" core FMIC
2.5" stainless mandrel bent intercooler piping
Carbonfiber oil catch can
2G Mass air flow sensor
Cone filter
Manual boost controller
Stock 1G BOV recirculated
Ported 2G exhaust manifold
Ported turbo exhaust housing
Ported 1g o2 housing
Full turbo-back 3" exhaust megan racing dp
Boost/Vac Gauge
Radiator 1.25" core
NGK BPR7ES .028
Balance shaft removed
A/C removed
FUEL
Walbro 190hp in tank
PTE 680cc injectors
TUNING
socketed Eprom ECU
Custom Steve P. Eprom chip
DRIVETRAIN
Built automatic with shift kit
IPT 4000RPM Stall
Dual flexplates
4Bolt LSD rearend
17" Enkei Weels
Yokohama YK520 tires
Things i dont like about it:
its vibrates inside which im guessin cause the balance shafts were removed maybe? is there a way to stop the vibrations? also a/c was removed.
ENGINE
Stock pistons
Stock rods
MLS headgasket
HUGE 3" core FMIC
Cone filter
Boost/Vac Gauge
Radiator 1.25" core
NGK BPR7ES .028
A/C removed
FUEL
PTE 680cc injectors
TUNING
socketed Eprom ECU
DRIVETRAIN
IPT 4000RPM Stall
Dual flexplates
4Bolt LSD rearend
17" Enkei Weels
