packinkimber45
- 379
- 2
- May 26, 2006
Boise,
Idaho
I was just going through my logs and posted one on dsmlinkforums too. Someone had mentioned on the forums and I also noticed it. My O2 signal in link is not cycling from .20-.80 as it should be. Instead it is goin .20, .80, .20, .80 and so on. What is going on. I have a new LC-1 wideband that was recently installed and a new sensor with it. I am simulating narrowband via link as well. It is a new motor that I just got done building and got started. Initially my original oem narrowband sensor appeared to be dead when the car first started, so I installed my lc1. What is going on, can I get some direction here, what do I need to do or check. Thanks.
